Power seat
Mike B
'93 Town Car, powers seat won't lower. The seat will move in all directions, but down. Can it just be a switch? If not can it be possible to replace just one motor, or would all three need to be replaced.
Thanks,
Mike B
The seat motors and track assembly are replaced as a unit. I have attached a description of how the power driver seat operates, the overview diagnostics and detailed diagnostics to determine the cause of your problem, and the procedure to replace the motors and tracks as a unit.
It appears your problem could be the seat switches or the motor grounds, or the seat motors or the tracks. Seat switches arc and get damaged over time, so that is a strong possibility. The grounds for the motors may get rusted and fail so those should be tested first and second in my opinion.
Thank you, This will give us something to do when it warms up.
