Robinelyse15
- Nov 20, 2018
Hi there, I'm getting the EATC code 81 in my 1998 LIncoln Town Car which I know is a "recirc door short" or "recirc door failure". and the chart that found says "GO to DTC B2416". I'm not sure what that means as an action lol. My door blend actuator has been replaced and you can see the door move when you change temps (open for cold and closed for heat). You can feel the heater box getting warm, but It still just blows kinda warm just not the 90 degrees its supposed to be.
Now I do get a sweet smell in the cabin like antifreeze and a fine mist through the vents which I think I fixed with a little stop leak but I still have the smell in the cabin. Not sure if that's a separate issue or not.
I feel certain it is something easy because the gentleman that I bought it from left the invoices in the glove box where he had the actuator replaced and then another invoice where he had it "switched" to blow cold air and said I could have it "switched" to heat when it gets cold. Well that invoice for switching was only $27.00 so shouldn't be too hard right? So what am I missing because im stumped. Thanks in advance for any answers.
