Need help with Aviator
Gooddriver
2025 Lincoln Aviator Reserve
Good day!
I have a 2025 Lincoln Aviator Reserve built in July of this year. I have a number of issues that the dealership cant figure out.
1. Banging, clonking noise from underside car, when driving forward slowly or reversing i.e. I am reversing into a parking spot or moving forward very slowly in traffic with intermittent application of brakes. Dealer says noise is normal.
2. Parking Brake Fault Service Now and Auto Hold System Fault occured 3 times time since i got the car. Have a pic of it but then it goes away and dealer says no fault code found.
3. Cold air blowing from under driver and passenger side front seats. My legs are freezing cold. Upper body fine. System is set to auto controlling both front and back at 23-24 degrees. Temperature gun readings at air blowing at dash level 25-27, and at floor level under seats 7-10 degrees. Dealer says no fault code found and blend door working fine. Dont have a solution for cold air blowing.
4-Buzzing type noise from ceiling console fan. Dealership replaced fan and noise went away for about a month and now its back. Dealership doesn't have a resolution.
If anyone has experienced any of these issues or has had a resolution to them appreciate the help.
