Mark MK
- Mar 30, 2024
- Lincoln Town car 1981
Hello Lincoln forum Members,
I have a 1981 Town Car with electronic instrument panel, it was used by an embassy in Paris during eighties and early nineties.
After many years without running, I made tune up, replacing oil for motor and gear box oil, brakes liquid and hoses and radiator water and hoses, spark plugs..., I also had to change the tank rusted inside and fuel pump.
I finally managed to start motor but the after many minutes the motor stalls and it was very hard sometimes impossible to start again during a while.
Gradually I decided to change many things like crankshaft position sensor, ignition coil, ignition control module, Engine Control Module, the engine control module calibrator, the fuel injectors, map sensor, I verified throttle position sensor, fuel pressure regulator.
However the problem is the same, the motor starts and stalls after a moment, if I tried to put in drive it can t move more than some feet before stalling.
The mystery remains !
