tiktok4321
- Dec 7, 2020
Perhaps I get some advise. My 2013 MKZ has about 152,000 miles on it. It's still pretty clean and useful, but I have a ton of "tiny" issues that I would like to resolve before trying to sell/trade/keep it:
1) Interior pleather is delaminating. I've tried to take the door panels off and tuck the pleather back in, but evidently it's supposed to be glued. What glue would I use?
2) Driver's interior door latch handle is pushed in. It still works, but why is that happening?
3) Radio won't pick up HD stations any more.
4) Nav won't read any Map SD card any more.
5) AC starts off most rides just fine. Then, it's like the mode actuator just gives up and starts blowing air somewhere except for any of the vents I select. Can't reset, but if I turn off the car for 15 minutes or more, it'll work just fine until it doesn't any more. Temperature seems to not be an issue at all. Hot is hot, cold is cold.
6) Weird smell out of AC. Cleaned my ducts, blower and CAF. Almost smells like glycol, but how? Strong, sweet-ish odor. Can clear out if I blow the motor on high for 5 minutes.
7) Fuel door came off hinge. Do I have to take the whole filler assembly out and replace it?
8) Trunk door won't fully shut on left side only. Looked for adjustment bolts, but can't find any. Body shop repair?
9) Engine sometimes clunks excessively on start up. Periodic transmission issues (clunking) when switching from P-->R or R-->D. Once it seemed excessive.
