Lincoln towncar signature series issues with parts
mindyburdette
I have a 2000 Lincoln towncar signature series that has the interior door panel....just at the line across the panel length wise that's busted and repaired...and busted again.
So the holes where the peg things go are wallered out...and the bottom part of the panel keeps getting caught in the door frame and it's all but ripped the bottom part off...
Anyone know where I can just buy the bottom part?. Any suggestions on how to fix it myself without buying an expensive part?
Is the bottom part of the interior door panel typically called something else...I can't find a Lincoln door panel anywhere... internet be damned!
Thanks!
23/24 year old vehicle seeking an interior trim piece that is usually unique to each model year.
Door panels usually do not come in separate pieces. Likely you may find a complete panel.
That will be a tough task.
Sources will be ebay, wrecking yards, places that are parting out your vehicle.
You might touch bases with LKQ. They are a nationwide wrecking yard. They may be able to find the car and then have some one check to see if there are door panels.
Try car-part.com for salvage yards near you with possible sources for the parts you need
Also, try looking on the back of the panel for a stamped part number. Then take that part number and google it for sources
(y)
