G
G-401893
I changed the purge valve and the charcoal canister I don't know what else to change to fix this problem
Could be anything from a bad ground , bad fuel filter to a bad PCM. I'd start with the cheapest and work my up from there. Do a complete diagnosis of electrical grounds under your car, battery load test, check and clean and dielectric grease all connections , ground cables, battery cables, all sensors and plugs cleaned and checked for rust on pins , all coil pack plugs cleaned and checked, throttle body cleaned and checked, and the list goes on and on and on.What year?
Which engine?
How many miles on the vehicle?
When does the engine stall?
At idle when vehicle is stopped
When coming to a stop
When driving with the accelerator pedal depressed
Kinda what I was wondering also ????Why did you change those parts? Are you performing any diagnostics or just firing the parts cannon?
