KnightSnake
- Feb 25, 2021
Hi everyone, I searched the forums and I have seen a couple of these threads, but no real solution to my problem. So I was driving my car (2017 Continental, still need to replace the door latches related to the recall), and as it was running low on wiper fluid I pulled over and wanted to fill up the wiper fluid. All was well, the door opened normally, I closed it normally as well (not locking it). Went to the boot, got my canister of wiper fluid and topped it up under the hood. I put the canister back and as I wanted to enter the car again the door would not open (small panic ensued as I thought somehow I locked myself out with the key still in the car, which is not possible unless you lock with the number pad or the key would not be detected). Also the door key pad lights would not light up. The rear door worked and the passenger door worked as well, but the driver door still refused. I pressed the unlock button and tried to open it again (from the inside this time with the normal door opening button), still nothing. Then I used the emergency release lever in the map pocket, that worked (obviously). Now... thing is after using that lever... the normal release buttons (inside and outside) both worked as normal again, as does the softclose... however as I wanted to drive away, the car chimed a warning notifying me of a driver door fault (red message), and also there was a (yellow wrench) see manual prompt. Now everytime I start this yellow wrench and red door fault warning pop up, seeing how the issue has resolved itself how do I get rid of these prompts? Would a battery reset (disconnect) help? Or would I need to do it through Forscan?
As for why I did not take the car in for the recall yet, this is because I am in Germany and its not that easy to get the parts here as technically the recall does not include countries that do not officially offer Lincolns here... but I will get them replaced ASAP... my local Ford dealer stepped up to the plate for me in the past to get me equal service to US customers.
Any ideas and help would be greatly appreciated!
