The car lovers social network
Dance Music Discussion
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Advertise with us!
This is 2024 Nautilus ReserveShould the car light up when you approach?
That would be useful info to put in the "My Lincoln" field of your profile so it shows in the margin when you post.This is 2024 Nautilus Reserve
So what happens if the key fob is never actually out of range at home in the garage. You just never get the embrace there, I'd imagine? It's like your dog — you don't get that excited greeting unless you left it alone for a while?Hi Dave1946. Yes, if you have the "Lincoln Embrace"/Approach Lighting/Welcome Mat enabled in the vehicle settings, and have a keyfob with you/on your person when you approach the vehicle.
Hi swindler. Yes…lol…that pretty much describes what happens.So what happens if the key fob is never actually out of range at home in the garage. You just never get the embrace there, I'd imagine? It's like your dog — you don't get that excited greeting unless you left it alone for a while?
The range is approximately 8 feet.So what happens if the key fob is never actually out of range at home in the garage. You just never get the embrace there, I'd imagine? It's like your dog — you don't get that excited greeting unless you left it alone for a while?
The Lincoln Embrace will time out after the pre-programmed time period. And won’t re-enable until the next restart.
Not sure what will happen it times-out with the key fob within range, then subsequently the key fob is moved out of range, then back into range. Perhaps the Lincoln Embrace would be active again?
I’ll check next time I have a chance, and post back with the results. Or perhaps you or another forum member will beat me to it.
Welcome to the Forum Dan.I thought that the Lincoln Embrace lighting only worked when the car is locked. But every time I walk into the garage (and the car is UNLOCKED) the lights come on. Very unnecessary and a drain on batteries! Is this normal?
I've tested this pretty extensively. In my house, the range for the key fob is 30 feet! It's 20 feet for the phone. That's not a good thing and why I now store my key fob in a Faraday box.The range is approximately 8 feet.
Welcome Dan.I thought that the Lincoln Embrace lighting only worked when the car is locked. But every time I walk into the garage (and the car is UNLOCKED) the lights come on. Very unnecessary and a drain on batteries! Is this normal?
So you can lock/unlock your vehicle from 30 ft away? If so, I wonder if someone without the fob on them could then open the door?I've tested this pretty extensively. In my house, the range for the key fob is 30 feet! It's 20 feet for the phone. That's not a good thing and why I now store my key fob in a Faraday box.
My guess is If Dan does the same thing as I do when pulling into the garage, he doesn't lock the vehicle so there should be no reason for it to be locked. Aside from the mirrors, I'm guessing if you swipe the Securicode panel it would show the locked symbol, although I haven't confirmed that.Welcome Dan.
Question - How do you know the car is unlocked? There's no obvious way to tell and the car makes no mechanical sound when it locks and unlocks. I have my mirrors fold on locking. It's the only way that I can tell if the car is locked or unlocked.
It's a very interesting question and I think I have the correct answer from testing in my own home.So you can lock/unlock your vehicle from 30 ft away? If so, I wonder if someone without the fob on them could then open the door?
And do you experience the same thing as Dan having the Lincoln Embrace lightshow with the car unlocked? As I said above, Lincoln Embrace and the car locking and unlocking are independent of each other. So I'm sure that it's possible.My guess is If Dan does the same thing as I do when pulling into the garage, he doesn't lock the vehicle so there should be no reason for it to be locked.
No, the Embrace Lights on mine do not come on if the vehicle is unlocked. They should only do so if the doors are locked and it detects the fob.And do you experience the same thing as Dan having the Lincoln Embrace lightshow with the car unlocked? As I said above, Lincoln Embrace and the car locking and unlocking are independent of each other. So I'm sure that it's possible.
Regarding not locking your car, is the car theft issue not as prevalent in greater Ottawa as it is in GTA?
I'll bite. How can it happen (unless the key or phone is left in the car as described above)?If anyone is confused about how this can happen, feel free to ask questions and we can elaborate.
