The car lovers social network
Dance Music Discussion
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Advertise with us!
Thanks for your input. I had never heard about the issues with cruise control and flashing speed.Never replaced headlights with LED type but the others should be no more difficult than replacing individual bulbs. Be advised…installing LED lights can sometimes play hell with a cruise control and/or turn signal flashing speed.
Very good input and answer Action.I have LED Hi+Low Headlights and Turn signals ,Brake lights Installed on all 4 of my Designers for over 2 years now with no affects on cruise control or any other system .For Turn signal,Brake lights it's a little more involved to do the conversion,had to go in the LCM on printed circuit board and modded to a electronic relay to eliminate Hyper Flash.A LED light consumes less power than an incandescent light.
Older turn signal flashers use current flow to heat up a bi-metalic strip that opens the circuit and cools the reconnects the circuit. Which creates the flash on and off for turning. With lower current flow of a LED the bi-metalic does not heat up and the turn signal light just stays on.
Speed control systems use the brake light circuit to shut off. This is a safety measure as a driver you do not want to slow down by stepping on the brake pedal and the speed control is accelerating maintaining speed that was set. With that said, some systems shut down with the brake application. Other systems are more or less on pause, The system is not shut off. It is just paused. Reactivation can be done by pressing the accelerator button, It is this system that will not work well with LEDs. The speed control system may not pause.
LEDs for any exterior running lights or interior illumination should have no adverse impact on other systems.
Ok, ok. I will try and get the LED lights installed. With duct tape and vasoline I can geterdunn!I just did LED headlights but had to (lightly) modify the locking ring on either the high beam or low beam (sorry, can't remember which). I used the Philips Ultinon LEDs and they look/work fantastic, just what I was going for.
Well, ya talked me into the hassle of installing LED headlights. I have been researching and watching installation videos and I see the small modification that needs to be done on the high beam side.LOL
Effort = hassle
Just depends on if the end result is worth the effort/hassle.
Which is a value judgement.
Getting out of bed in the morning can be called a hassle. Most of us believe the end result is worth that hassle.
Good luck, they're totally worth it.Well, ya talked me into the hassle of installing LED headlights. I have been researching and watching installation videos and I see the small modification that needs to be done on the high beam side.
Outstanding! I’m in the process of going LED in my bulbsI replaced th3e back up light with LED. I couldn't see a thing with the factory lights. I have no issues with LEDS.
