Leaking Coolant - 1988 Lincoln Town Car
  • Thread starter Thread starter mongoose69
  • Start date Start date
M
mongoose69
ABS Conversion
Hey All
I have done the abs conversion. I know there are always questions on this but I have all
the braking force in front. So when I apply the brakes it nose dives where should I install the adjustable prop valve and also what about installing a residual valve also? Please help me on this. It has been doing this since i did it the conversion about six months ago.
ABS Conversion
[quote name=\'mongoose69\']Hey All
the braking force in front. So when I apply the brakes it nose dives where should I install the adjustable prop valve and also what about installing a residual valve also? Please help me on this. It has been doing this since i did it the conversion about six months ago.[/QUOTE]
Six months doin nose dives. Well you might want to get that fixed. :chin:
Prop vavle can go anywhere, install it and adjust it. I put mine on the shock tower, but i\'d rather install it under the MC. When i plumb the line lock i will move the prop valve. Anyway, you should be good after doing the above.
ABS Conversion
What do you mean by a splitter ? Like the ilustrsation shows from this web site. This is how they are done. Why would the fronts have all the braking? by installing the valve will the brake pedal be stiffer?
