Intermitten fuel pump problem
jhh3411
Atlanta
Hello I am new to the forum. I have a 2000 town car with 118k. I have been having an intermittent problem. When I come up to a light or stop in traffic at idle the car will cut off. There is no skipping. I try and crank up and it will sometimes "diesel". I pulled the fuel line from the filter turned the key and no flow. It has only happened in the heat of the day with temps is in the 90s. After it cools it will crank up and run great. I have replaced the fuel pump, filter, and the relay. What could cause this and set no codes? Please help thanks in advance
