If it is like my 06 Navigator, it is not difficult.
I changed the right side of my Navigator about a year or so ago when I discovered a torn boot.
About a month ago I found the left boot torn. The joint is not loose yet and I have the replacement. With daytime high temps in triple digit and nigh time lows in the 90s, I am waiting a few months to do the left side.
I am in Phoenix. Hardly rains so moisture does not really splash around and get past the cut bott much. So waiting is not that big of a deal.
R&R - from memory
Shut down the air compressor, jack up the vehicle and remove wheel after putting stands on the frame
Disconnect the air line, the sensor and air suspension strut (top only)
Unbolt the ball joint. May need to wack the joint with a pickle fork. Only use a pickle fork if you are NOT reusing the joint
Unbolt the two upper control arm pivots and remove
Remove the upper control arm
Reverse process to install new arm
Again, because of climate there is no rusty fasteners that I deal with. And at the mid point I clean everything and treat all of the rubber and plastic that I can reach. After changing out the right side there was NO difference in steering and no abnormal tire wear after driving for a month. So, I did not get an alignment. Good thing as I will likely get an alignment after I change out the left side this fall.
