• 🔍 Like our community? You can tell Google to show you results from this site more often. Just Click Here and then click the empty checkbox on the right side of our name.
Hidden menus in the 2025 Corsair GT
As an Amazon Associate we earn from qualifying purchases.
tadiv
SUPPORTING MEMBER +
2025 Corsair GT
I'm looking to the button press sequences that enter "Engineering Mode" for the main display and the SYNC 4 maintenance menu. Web and "AI" searches all give me sequences that I can't use (like pressing and holding Seek-Right and Volume Down - since I have a "joystick" on the wheel that has both of these functions, I can't hold them both)...
Suggestions?
Thnk you in advance.
Suggestions?
Hello and welcome! Frustrating when generic AI searches give you instructions that are physically impossible for your specific steering wheel.
It sounds like you're dealing with two completely different diagnostic menus here, and those generic searches were completely steering you (no pun intended :p) wrong on the SYNC 4 sequence. Pressing volume down + seek right is actually the reboot sequence for the Mustang Mach-E, not the diagnostic sequence for the Corsair!).
Here are the correct sequences for your Corsair GT:
1. Instrument cluster engineering test mode (ET mode)
This mode tests the gauge cluster, chimes, battery voltage, and raw sensor data.
- With the car completely off, press and hold the OK button on your steering wheel (the center press of the right hand directional pad).
- While continuing to hold OK, press the engine Start button once to turn the ignition to accessory mode (don't put your foot on the brake - you don't want the engine to start).
- Keep holding the OK button for about 5-10 seconds.
- The letters "ET" or "Engineering Test Mode" will appear on the instrument cluster screen. You can then release the OK button and use the up/down arrows to scroll through the hidden menus. To exit, just turn off the vehicle.
2. SYNC 4 / main display maintenance menu (APIM diagnostics)
This menu lets you test the touchscreen, speakers, telematics modem, and view active accessory protocol interface module (APIM) fault codes. Since you can't physically press volume down and seek right on your left joystick at the same time, you have to use the vehicle's secondary sequence.
- Turn the vehicle on (accessory mode or fully running).
- Make sure the audio is turned on (playing the stereo is fine).
- On your steering wheel's left joystick, push and hold to the right (seek right).
- At the same time, press and hold the seek right / skip forward button on your dashboard's physical media/climate control panel below the screen.
- Hold both buttons together for about 10 seconds.
- The screen will suddenly drop into the speaker walk-around rest. Once that starts, you can hit "end test" to back out to the main bezel diagnostics menu.
If you ever actually need to force a soft reboot of your main screen because it freezes, the sequence for the Corsair is to press and hold the physical power button - the center of the dashboard volume knob - along with the seek right button on the steering wheel for 10 seconds until the screen goes black.
I don't have a console seek right / skip forward button (see attached photo).
For the ET menu, my joystick does not press in at the center position - OK is a position to the right that is illuminated when it is needed - there is not an "OK" position when the car is off...PXL_20260628_191700179.MP_e.webp
I found the SYNC 4 "Bezel Diagnostics" menu - With the audio on (for me it was FM Radio) press and hold the console audio power button while holding the steering wheel Volume-Down toggle - after several seconds the speaker test will start.
Resetting SYNC 4 - hold the console audio power button and the steering wheel Skip-forward (right-pointing arrow) for several seconds and SYNC 4 will reboot.
I have not yet figured out the Engineering Mode...
Tom
@tadiv, thank you very much for following up and sharing those exact button combinations! That's a fantastic find and will be very helpful for other Corsair owners on the forum who are running into the exact same issue. Looking at the console layout and the capacitive steering wheel in your photo, it makes perfect sense why the older manual button methods failed for you.
Regarding the Instrument Cluster Engineering Mode, you're running into a physical roadblock that a lot of owners with the newer capacitive steering wheels are discovering. Because your OK button is not a physical switch and completely powers down when the ignition is off, it's impossible to perform the traditional sequence of holding the button down before turning on the vehicle.
Unfortunately, it appears Lincoln has locked out manual button access to the instrument cluster Engineering Mode on these newer digital dashes because of this hardware change. At this point, the only reliable way to view that raw cluster and sensor data on the newer models is by plugging in an OBD2 diagnostic scanner and pulling the information through software like FORScan.
In any event, thanks again for posting those SYNC 4 sequences for everyone.
