flashgordon
- Sep 25, 2014
I'm looking for some much needed help with an ignition problem in my 1971 Lincoln Mark III. I had to replace the ignition switch on the lower steering column but the key positions are not working right. The ignition switch has 4 positions which should match the key positions: lock, accessory, on, and start, in clockwise order. The Engine starts in the start position but won't shift into drive. Also, accessories come on in the lock position but not in the accessory position. I have taken apart the key switch and tried aligning the gear in different positions with the ignition switch, but no luck. I have considered the brake pedal switch, but since the tail lights come on, I'm assuming that's ok. I'm not sure where to go from here. Any ideas would be greatly appreciated. I have spent a ton of time on this. Thank-you.
