darylfeist
- Nov 15, 2021
2004 Town Car Sinature series, 4.6 ltr. Door ajar warning on dash, intermittent, does while driving or parked. Sometimes it won't di it for days, then starts again. Replaced door ajar switch on driver's door, no change. Tightened and lube all areas of all latches, no change. I've read another thread about ddm module replacement, the guy did that 3 times, still an issue. I'm considering replacing it, I'm a diy person at home, no forscan, whatever that is to check it, I have a scanner that plugs in computer, can read codes and reset /erase fault codes. Just installed a new battery, 2021 batt died this morning. AAA replaced, alternator/starter, good. I'm at a loss, I don't know how, where to look to check connectors,pins, wires, because I'm not a mechanic with all data,online tech service subscriptions, etc...I used to drag race an old 67 stang in the 80s, rebuilt /repair/hot rod shit/paint/weld, even worked on jet engine components at Kelly AFB. Where the F can I get hands on information,detailed instructions. Are there tech manuals anymore? Sure is nice having something on actual paper to refer to different sections while working on a car ! Helppppp!
