I use the auto folding button every day. When I push it both mirrors fold in. When I push it again to unfold them only try passenger side one will unfold and not the driver’s side unless I manually do it. All my owners manual says is to use this button to reset it. Is that it? If so it doesn’t work since I use this every day.
Hi Kenneth. What my Owners Manual states is the following for resetting the power folding mirrors:
"If your power-folding mirrors are manually
folded, they may not work properly even
after you re-position them. You need to reset
them if:
• The mirrors vibrate when you drive.
• The mirrors feel loose.
• The mirrors do not stay in the folded or
unfolded position.
• One of the mirrors is not in its normal
driving position.
To reset the power-fold feature, use the
power-folding mirror control to fold and
unfold the mirrors. You may hear a loud noise
as you reset the power-folding mirrors. This
sound is normal. Repeat this process as
needed each time the mirrors are manually
folded."
If yours states the same and that does not correct the situation, or is different and still did not work, then you should schedule a service appointment at your earliest convenience.
Again, I would advise against other types of self-help fixes, like battery disconnects etc., since they can wind up temporarily masking a larger underlying issue, and the Service Department can not properly diagnose and fix something that is temporarily working when they are looking at it.
