Driver Door isnt working
castillomoises50
1997 Town Car Cartier
Hello I'm new to this forum. I recently got my driver window regulator replaced and ever since then my whole driver door doesn't seem to be working. Window works but everything else. Seat adjustments, locks, Side mirrors, heater, keyless entry isn't working. Went through the fuses bought a new one thinking it was burnt(20 C.b) still nothing wondering if anyone has experienced this problem or just general insight of this problem anything would help
Hi castillomoises and welcome to the Lincoln Forums. If it is not fuse related, then it sounds as though the shop (or individual) that replaced the window regulator did not reconnect everything properly when they reassembled the door.
You should bring it back to them to have everything checked.
The shop has already told me that the work is not guaranteed the part is. So the shop is no help. It's just something I want to get fixed
If they put it back together without plugging all the connectors back in, that's not really a matter of work guarantee, that's a faulty job and you should take it back. When shops say no labor guarantee, they generally mean that if the regulator fails again then the part is guaranteed but you have to pay labor again.
It's possible your driver door module went bad, but at the exact same time? That's too much of a coincidence.
Ok so I took it back to the shop they showed me that everything was connected no wires were damaged nothing that looked out of place or damaged. Still not working.
You need a drivers door module, not a window regulator.
Do I need to program the module or is it just a plug and play?
Some have sourced one with their "as built" options on the vehicle, and have not had to,..... if you source one without your "as built" data you might have to, I'm not too sure they can be flashed and reprogrammed though without getting a dealer involved , thus more money.
You have some of the classic symptoms of needing a DDM though from your post. Before you going throwing parts and money at this, open that door panel and look around for a broken wire or a bad ground or anything else that doesn't look right, the mechanic could have knicked a wire in there or cut a wire pulling out or putting in the panel or regulator.
