Couldn't find forum for MKC so trying luck here
spartingroup15
2017 MKC
Hello I have a 2017 Lincoln MKC 2.3l. It was in a front end collision started putting it back together and was running fine last week I put the fenders back on and only have the bumper and headlights left. After installing I started and it ran fine this week I went to work on it tried starting it up and it powered but had no crank. The transmission sounds to be shifting fine. I got a few errors Steering assist fault, check rear parking aid, Blindspot sys fault, cross traffic sys fault, see manual, and full accessory power active. checked my fuses under the hood seem fine relays are going to be tested soon and the starter was taken out and tested at o Reilly's and it passed. Any advice?
Hi spartingroup15 and welcome to the Lincoln Forums.
If you look towards the top of the page, there is a listing of the sub-forums for the various Lincoln vehicles (on my screen, the lettering is blue). The Corsair/MKC sub-forum is the first one listed. Although your problem sounds like a more generic, non vehicle-specific one, you may have more luck posting your questions there.
For your specific problem? Blind Internet diagnosis is problematic at best. Could be anything as simple as a weak/failing battery, loose ground etc., to something more complicated.
To rule out a weak/failing battery, the first thing I would try would be to jump your MKC from another vehicle, or a portable battery jumper pack if you have one.
If that does not work, hopefully another member may have run into this before and be able to offer more advice.
Keep us updated and good
thank you so much was able to post it on there. I replaced the battery 2 times to give it the benefit of doubt. I’m starting to think it could be my computer but my obd 2 is able to communicate to it without a problem so I’m not too sure. Was able to buy a adapter for my computer to see if I can pull any information from forscan.
