Adjustable pedal fix!
Curless Auto
Hi there, new to this site but not to the game. I have a 2003 Marauder and the pedals did not move when I bought it. After some research I found that it was a huge issue with all of the Panther cars of that era. So I came up with a permanent fix. Here's the instructions with some photos! If you have any questions or would like a gear let me know.
O.K., there has been a ton of talk about how to permanently fix the pedal assembly that fails on our cars. I have such a repair. I had a gear designed today made out of brass to replace the one that is plastic.
The cost will be $80 for the gear shipped to your door.
The gear is locked onto its shaft by being stamped, this will require grinding the shaft end down so that the washer can be removed and the offending gear can be taken off. Then you would instal the new gear, and attach the push nut supplied with it.
1. Move your seat all the way back
2. Disconnect Battery
3. Remove lower cover under the dash that covers the pedals up. I order to do this you need to remove the three black push pins that hold the cover to the bottom of the dash. Then draw the cover down and forward to dislodge it from the retaining clip at the firewall side. DO NOT pull to far forward because you need to remove the courtesy light from the cover first.
4. Unhook the brake light and cruise control wiring from their connectors.
5. Remove the cruise control switch (upper left switch in the pic)from the pedal assembly. To do this you simple grab the switch and turn it about 45 degrees COUNTER CLOCKWISE.
6. Remove the yellow spring clip from the pedal stud.
7. Slide the washer off from the pedal stud that you just removed the clip from. Now you can apply just a little bit of pressure to the brake pedal to release the rod from the brake booster and the brake light switch from the pedal stud.
8. Now we need to remove the drive cable from the brake pedal. This can be one of the trickiest parts of the whole deal. Look closely at the cable end nearest the pedal. There are two small sides that are solid and two larger ones that are not. If you squeeze the solid ones, they are supposed to release the open ones...yeah right, so I used a small screwdriver to help slide the locking edge over its rim. BE CAREFUL not to pry too hard. It will come off you just have to hold your tongue right!
9. Remove the 10mm headed bolt that is located straight up towards the top of the dash. Next remove the four 14mm nuts that are on the studs coming through the firewall.
10. Now go outside under the hood and pull the master cylinder and brake booster forward just enough so that the studs are on the engine side of the firewall. You will move the master cylinder assembly over to the driver's side just enough so that the studs can't slide back through.
There is a black piece of plastic that is a spacer in between the pedal bracket and the firewall. It may fall down or out while removing the pedals. We will address that on instal. So for now just pull it out of the way when it is necessary.
11. Now for the next tricky part, removing the pedals. The bracket the holds the under dash cover needs to be bent froward so that it is out of the way. The pedal assembly is then twisted clockwise and drawn out pedal first and then the top. It is tight, it does not want to fit out of here but if you take your time it will slide right out.
12. Now for the actual repair. Set the pedal on the bench and remove the two T-20 torx bolts from the plastic housing.
13. Next you have to GENTLY pry the cover off by releasing the 6 tabs and prying upward at the same time. Two pocket screw drivers work best.
14. SAFETY GLASSES ARE A MUST!!!! CAREFULLY remove just enough of the swedge (metal) above the washer so that the washer can be removed. DO NOT grind the snot out of it. Just grind enough so that you can see that the washer surface has been touched. I use a die grinder with a green (01396) 3M roloc disc on it.
15. Once the swedge has been removed from above the washer turn the gear down so that it is as far away from the washer as it can be.
16. Mount the pedal assembly in a vise as shown or have someone hold it still so you can knock the washer off with a hammer and chisel.
17. Remove the old gear.
18. Apply grease to the threads in the pedal. Your favorite brand is fine. We use Sil glyde.
19. Thread your new gear onto the shaft. Apply some grease to the outside threads on the new gear.
20. Instal the provided cap washer by setting it on top of the end of the shaft and lightly hammering it on.
21. Now you need to line up the pedal so that when we instal it we are synched with the gas pedal distance wise. look at the right hand side of your pedal assembly, there is a mark / notch on the side right above the slide for the pedal. You need to adjust your gear so that the pedal is exactly lined up with this mark. You do this by simply threading the gear.
22. Now we can re-instal the cover. Be sure to add some grease to the worm gear as well. Do not over tighten the bolts.
23. Back together, first the pedal assembly goes back in place. The black separator piece must go in between the pedal and the firewall BEFORE you slide the master cylinder studs back through. The trick I have learned is to set the pedals in, set the plastic piece in, then instal the 10mm bolt in the top of the pedals to hold everything in place. You should then be able to line up the pedal assembly and the plastic piece so they master cylinder studs will slide right through them both.
24. Once the studs are through the pedals take the 10mm bolt back loose and instal the four 14mm nuts and tighten them. Now re tighten the 10mm bolt.
25. We now must set the gas pedal to match the brake pedal. Re - connect the battery and set the gas pedal as low as it can go.
26. You now pick up at step 8 going backwards for the rest of the instal.
Can't figure out how to post pics on here yet..I am not much for computers...if you have any questions please feel free to call me 616-988-1315 ask for Chris
To post pictures you need to select the "Go Advanced", that will take you to a "preview screen" and a "your Message" screen is below. If you scroll down you will see a box called "Manage Attachments" and select this. A small window will open and in the top right there will be an "Add Files" box with a green +. Select that box and you will see a "select files" box under the small window. Selecting that box will take you to your computer files for file selection. Select individual files by clicking on them or select multiple files by holding Ctrl and selecting all the files you want. Then select open. You will then be back at the small window and the files will be added. Then select "upload" and the files are transferred to the bottom row of the window. Select "Done" on the right of the box and the window closes. Your files will be displayed under the Manage Attachments Box. Now select "Preview Post" and your files will be displayed at the end of your post (in the Preview area).
Your done with attachments, but you can re-order them if you want.
Finish your post in the "Your Message" area and preview again or select "submit Reply" to post your thread or post to a thread.
If you notice something that you want to change after posting then you will have some time. Look for the "Edit" on the bottom right area and select that and go advanced if you want to add pictures or change text. It operates the same as the original posting.
