rancourt
- Jan 14, 2022
Okay. As promised, Part III of the cabin air intake saga that began in Parts I and II elsethread -- the installation of the cabin air filter. It's really simple. So, having heard a rumor that a contemporary Jeep Grand Cherokee's cabin air filter fit nicely, I picked up a UAC FI 1062C cabin air filter, trimmed a little off of the tapered end, and slotted it into the "box" area over the cabin air intake. I used a little painter's blue masking tape to hold together the end I cut, but it didn't prove necessary at all -- these filters chop neatly and stay together after chopping! (Just take care to remember which direction air's meant to flow through the filter, if you cut away the indicator...)
So, since the entire intake area was on the left side, and only filled about half the total space:
...I cut myself a little extra length, and used it to fold in the corners at the far side, creating an easy-remove "notch" in the filter naturally, where it's not actually needed to block airflow, far from the intake itself.
I could have trimmed a couple more ribs for a perfectly flush fit, but again, that "notch" will make it easier to remove one day, at no loss of filtration, since the area it needed to cover was all toward the left. The filter fits perfectly under the cover, and between the gasket and the filter, I note that I have improved airflow through the dash vents, which surprised me! I'm guessing that, in addition to water getting in through the gap there, the imperfect seal wastes a little of the pull force of the intake fans. My wife and I both noticed a clear difference, post-install -- two bars on the fan was now as powerful as four bars used to be! Your mileage, of course, may vary, and I'm not sure that's a normal gain -- maybe more a sign that my own intake was leaking air as well as water -- but it surprised us.
Really, really glad I could share this process with all of you, and hope it helps someone in the future!
