Yes, it's obviously going into the dealer. With that being said, I'm asking here in case there's a weird nuance/quick fix that folks have come across before. taking it in is a pain with the lack of loaners and logistics. Vehicle has less than 10k miles on it and isn't even a year old, so even i found a quick fix now it'll still get looked at in the long run.
Hi TXNav. Yes, I 100% understand why you asked here. For the same reason everyone else asks here and on other forums.
However, as I tried to explain...Since it is relatively safe to assume your vehicle is still within the 4 year/50,000 mile New Vehicle Warranty, it would be better
not to try self-help "quick fixes".
Again, the reason for that is the following: Keep in mind once you try a quick fix/band-aid and it works, you will not be able to bring your vehicle in for a repair until the problem occurs again, since the Service Department can't diagnose and fix many/most problems if it is not happening right then.
In other words, you can't bring your vehicle in while it is working properly and say, "My air conditioning is working now, but would not work last week. Please find out what the problem is and fix it". If you do, they will tell you to "Bring it back again when it is not working." And your warranty may run out by then.
Far too many times, owners who find some online "quick fix" discover the "quick fix" (i.e. things like battery disconnects, system resets, etc.) only put a temporary band-aid on the problem. However, the underlying defect/problem/cause was still there. And the underlying cause will most often rear its ugly head later, and lead to it happening again. And Murphy's Law tells us that it will happen again. Usually at the worst time. Usually after the warranty has expired and we have to pay for the repair.
You are obviously free to do whatever you wish with your own vehicle. And my reply will not hinder anyone else from posting their "quick fix", if they know one.
I'm simply giving you advice learned from many years of being taught by others who knew what they were talking about, and subsequent experience.
