NaviatorinAZ
- Jan 17, 2017
I just bought an 04 aviator AWD. 130k miles
Should have done more research, but now have an engine that needs timing chain guides and tensioners. (Changed the oil and found orange chunks and no fine aluminum dust in the oil). Took the oil pan off and the nylon guide from the upper guide/tensioner fell out. Chunks of orange were in pan and screen.
Now. Knowing what lies ahead, must I change the timing chain and cam sprockets along with the guides/tensioners?
The repair computer program shows tensioner r/r being an 8.8hr job but a dual timing chain r/r is a 13.3 hr job in labor.
I've talked to the (non-dealer) mechanic and he seems to believe timing chains rarely fail rather failure comes from letting the tensioners fail thus causing and chain reaction.
Anyone else just opt for the guide/tensioner repair?
Thought the chain comes off to replace the tensioners and guides so I don't understand the 4.5 hr difference in estimated job time?
I would be doing this job myself but injured my back in the service and was medically retired. Can't lean over the engine compartment too long, but also don't want to get screwed out of several hundred bucks.
Thanks for any advice.
