driller
- Jul 30, 2009
- Location
- Morgantown, WV
- 2024 Navigator L 4x4 Reserve / 8 Passenger / Monochromatic / Equipment Group 201A / HD Towing Package
I can't imagine "unplugging" the shock absorbers would work without wreaking havoc to the vehicle in terms of warnings and whatever system defaults may be in place.
For those who may not understand the working theory behind these types of shock absorbers, here is an AI clip...
Unplugging them in theory would likely leave the shock absorbers in a 'soft' state as the whole design theory relies on 'stiffening' the shocks on demand by magnetic force to the fluid inside the shock and depending upon the particular design, possibly affecting any variable valving inside the shock.
Magnetic fluid shock absorbers, also known as magnetorheological dampers, use a special fluid that changes its viscosity in response to a magnetic field. When an electric current is applied, the magnetic particles in the fluid align, thickening it and allowing the shock absorber to adjust its stiffness almost instantly, improving ride comfort and handling.
