2023MY Front Camera Washer Retrofit
MattMacMan
Oklahoma City, OK, United States
2023 Lincoln Nautilus Black Label
For those that may not know, Lincoln quietly deleted the front parking camera washer jet on the 2023MY Nautilus. I have retrofitted the washer nozzle to my 23 BL successfully. The Emblem will need swapped (or cut) to accomodate the newly installed jet. Then 2 hoses will need to be installed. One goes inside the bumper and its VERY obvious where they clip in (clip points in the bumper are already there, white plastic tabs) then youll need the washer jet itself (literally clips right onto the camera in the grille itself), and the hose for the engine bay (you need the Y splitter piece of it, just pop it off and install it onto the existing wiper washer hose (little white tape indicates front hose, non-marked hose is for the rear) which is attached at the back of the reservior which is accessed through the pasenger wheel well liner).
Y-Hose: ka1z17a605b
Bumper Hose: gt4z17a605e
Nozzle/Jet: ka1z17603a
I just bought mine yesterday. I didn’t realize it didn’t have a washer. My 19 Edge did. Could you past some pictures/ instructions?
Its incredibly easy. If you buy the above parts, (all are required) it already comes with all the clips pre-installed. The bumper also already has the brackets where those clips go. The hardest part is removing and reinstalling the bumper. Which is simply basic hardware, nothing special, but its time consuming (whole job should take an hour maybe 2 at max). Anyway, attached are the official Ford removal and installation guides. Let me know if you have questions. Its plug and play, no programing or modules necessary.
