Hi,
Alright, I bought a 96 Town Car a couple of weeks ago. When I first purchased it the check engine light was on. Overall, the car runs smoothly but does seem to surge sometimes, like when stopped at a stop light it will increase in rpm with no pressure added to the accelerator peddle and I have to apply more pressure to the brake to keep from moving forward. When I took the car back to the dealer for the inspection I told them about the stall that occurred while driving on the highway with no previous symptoms. They ran diagnostics and stated that it wasn't "throwing any codes" and they reset the check engine light. I don't believe them about no codes. Had a local mechanic look at the vehicle and all was in good shape. Car starts right up at the beginning of a trip. Car dies while driving and while idling. Range in time for the car to stall is anywhere between 5 min and several days. The battery light comes on briefly right as the car sputters briefly then no power, and then the check engine light comes on. Both lights go off about 5 seconds later. Car will start up about 30 seconds later. Someone had stated the ICM conduction is increasing in resistance and the component can't dissipate the heat fast enough and interrupts signal. Not sure about that because it has died when the engine was warming up and at about half of the normal running temp. It has also died at normal engine temp. MPG is about 20, which I think is about right since the weather temperature has been around the 30's and I do mixed highway/town driving. I have ran sea foam- no help. Another thing, the ignition tumbler is broke; no key is needed to start the car (didn't know until a few days after buying).
Any help would be appreciated,
Topher
Topher
