DigitalAviator
- Jul 24, 2015
Hi all,
Anyone run into a problem with the cooling fan where it roars loudly under normal acceleration? The Aviator sounds like the roar of a heavily loaded semi accelerating...there's a ton of fan noise, but you dont have the thing floored and you're not really moving very fast.
So far, I've replaced the electric cooling fan relay (no change to the roar) and replaced the fan clutch. The roar used to happen 90% of the time regardless of engine temp, rpm or anything else. With a new fan clutch, the roar happens for about the first 60secs after i start the truck when the engine is cold and occasionally comes back if I'm stuck in traffic. The fan clutch I bought was a Four Seasons part from napa. Anyone think I should take that back and get a Motorcraft part? Any other ideas?
Thanks.
Thanks.
