The car lovers social network
Dance Music Discussion
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Advertise with us!
Could just be a relay blown. Check the fuse panels and the Owners Manual as to which one is for that cluster that is out.Please help!
I have a 2016 MKZ. Recently I have lost power to the passenger side, no climate control, no radio control, air bag light is on. Anyone experiencing the same issues?
Thank youCould just be a relay blown. Check the fuse panels and the Owners Manual as to which one is for that cluster that is out.
Did you ever figure out the problem. I'm having the exact same problem with my wife's carCould just be a relay blown. Check the fuse panels and the Owners Manual as to which one is for that cluster that is out.
Did you ever figure out what the problem was? My wife's car is doing the exact same thing.Please help!
Sorry, no i haven not fixed the issue. I just have to keep resetting the error codes.Did you ever figure out what the problem was? My wife's car is doing the exact same thing.
Does resetting the codes area make the ac kick back on?Sorry, no i haven not fixed the issue. I just have to keep resetting the error codes.
GREAT NEWS!!! I was able to fix the problem with my MKZ. My battery was low and did not have enough voltage to power all of the electrical components in the car.Did you ever figure out what the problem was? My wife's car is doing the exact same thing.
Quick question. So the car not getting enough power was the culprit to this issue? I currently have no climate controls, heated seats, heated steering will, blind spot and collision warnings are out and can’t control passenger side windows. I have searched everywhere for answers! Winter is almost here and I just want some heat in my carGREAT NEWS!!! I was able to fix the problem with my MKZ. My battery was low and did not have enough voltage to power all of the electrical components in the car.
Get a new battery.Quick question. So the car not getting enough power was the culprit to this issue? I currently have no climate controls, heated seats, heated steering will, blind spot and collision warnings are out and can’t control passenger side windows. I have searched everywhere for answers! Winter is almost here and I just want some heat in my car![]()
My battery was just tested and it was deemed good. This problem started over time with the climate control clicking on and off. Now the lights briefly come on after the car has sat but then go right back offGet a new battery.
Yes the battery was changed by my local Lincoln dealership. I have no further issues since the battery change. Good Luck!Quick question. So the car not getting enough power was the culprit to this issue? I currently have no climate controls, heated seats, heated steering will, blind spot and collision warnings are out and can’t control passenger side windows. I have searched everywhere for answers! Winter is almost here and I just want some heat in my car![]()
I am having the exact same issue, i replaced the battery, reset BMS, everything, check the wires under the seat, the fuses and still nothing. Anybody else experiencing the same issue and fixed ?Please help!
Thank you so much man, im going to look up on that wire, intried a lot of different things also and nothing. I’m in florida summer without AC its a sauna inside of my car. I appreciate your help, I’ll let you know if its the same issue. ThxI literally had this issue going on for 2 years. Took it to the Ford dealership twice but no luck. I almost scraped the car!! My climate control as well as blind spot did not work. Well after replacing module after module, I finally sent it to a car electrician. The guy had my car for 7 weeks looking for the culprit! $2000 later, it was discovered that there had been a corroded connector on the rear passenger side between the backseat and trunk. This was due to moisture getting in through the trunk. He dispatched the connector piece and wired the two wires back together and wala!! Everything works again! These cars have so many networks that communicate! This is an easy fix but a hard find if you don’t know where to look. If I were you, I would take it to a good mechanic whom does electrical work. Tell him to start diagnostic in the trunk or backseat to find which networks are offline. This can be done within an hour. That way he can narrow down the network and zero in on checking those wires and connections instead of them searching the entire vehicle like they did mine. The culprit is a cheap peace of plastic that corroded after time. My mechanic literally replaced nothing! Just cut out the connector and joined the two wires together. I know how much of a pain this is, and I got ZERO help from anyone. So I’ll try to help you pinpoint the issue as much as possible since nobody else has solved it
