Yeah, you might have a fire if you go with over 20. Even 30 will probably blow since you have a short. If your alarm is going off and/or door ajar light is always on, then short its usually in the door jam or inside the door. You could try bypassing it by installing a magnetic switch on the door jam. This utube vid is amateur using illegal splices and quick connectors which is a no no..... but you get the idea. I went with a better magnetic switch and didn't tear apart all the wires. The most difficult part was to make sure I cut the correct wire. I don't think the wires from this 2007 Ford Edge is the same color as yours. Everything works as OEM and haven't touched it since I did it 4 years ago.
But if your vehicle's problem is something else, then this won't work.
