Windshield washer pump
Aryc1221
I've been having problems with my 2010 mks ecoboost, when I use the windshield washer it blows the fuse, the wipers alone function until I attempt to spray aswell then it blows the fuse, I thought it was the pump drawing to much because it was broken, disconnected it tried pressing the but nothing happened like I expected and it did not blow the fuse while leaving the wiper blades functioning. I put in the new pump tested it and it worked but now maybe 2 weeks later and only a few times using it, it is blowing fuses again. I don't know if it could be a relay or switch, if anyone's dealt with this or has an idea I'd appreciate any thoughts.
thank you
