what the HELL
oldfred
Trying to find a forum on Lincoln Mark IV. Just found some BS but NO real info or help here. Can anyone suggest another forum ?
oldfred
Trying to replace the headlight switch, Having a problem getting to it.
I have torn the dash apart (removed a bunch of screws) but still no access.
also...
A/C works but the fan doesn't seem to move enough air. Fan works on all speeds but is quite noisy on high.
I don't see any way to access the fan..
I would like to purchase a shop manual for the 1976 mark IV.
would Like to have a Vacuum routing diagram.
Patroy
Might have a mouse nest in fan box.
I had that issue, pia to get to from under dash pass side but doable. Give me a few days to get a pic of the vac route chart.
oldfred
Thanks PATROY, hard to believe LINCOLN made this maintenance so HARD.
and its been 100 degrees here every day, too darn hot to work on this.
