wet floor drivers side
MKX
Recently noticed water saturation on drivers side floor in my wife's 2008 MKX.
Not one to believe in coincidences, water was noticed after a windshield replacement. After further water testing the windshield I've realized the only time water accumulates is after A/C used. Anyone have a suggestion what and were to check?
The car is scheduled to be checked by Lincoln.
11MarkX
5
I'm with Carr142. Instead of dealer, See this Youtube link, because it's an easy fix. Just use compressed air sparingly into the A/C unit. You only need a little pressure to clear the plug.
enigma-2
21
2nd on easy fix. One other thing you should consider is whenever this drain plugs and water starts to stand, it can create mold.
After you open the drain, consider pumping a can of Lubegard Kool-It into the heater/evaporator core housing. It foams up and kills any mold. Then turns into a liquid and drains out. Nice and fresh.
You can work the clear plastic tube in through the vent opening, making it a simple, quick job.
