Upsizing tire sidewalls (40 to 45) - advice or experiences
NautiOne
Arkansas
I currently have 265/40/R21 tires on my 2020 Nautilus and am considering upsizing the tires (for sidewalls only) to 45 aspect ratio (265/45/R21) to make the ride even more comfortable. Has anyone done this? Any advice? I do realize that the speedo will display a slightly lower speed than actual.
1,380
Hi NautiOne. The 265/45-21 tires will fit. And as you stated, the speedometer will be slightly off. You will be going slightly faster than it reads. And the odometer will also be slightly off. Not enough to worry about in either case.
On a related note: Not sure how worn your current tires are and what you are expecting as far as a ride improvement. Apples to apples with tires, there will be some ride improvement, but it won't be significant. Certainly not worth the cost if you do not actually need new tires yet.
Therefore, I would recommend getting the full life out of the tires you have, then spending the money to make the switch.
NautiOne
Arkansas
Thanks for the input bbf2530! Currently have the Conti CrossContact LX Sport w/ 27K miles. There is still 6-7 /32s remaining. Reviews on these are not great, but I have no complaints.
1,380
Hi NautiOne. If you are happy with them, that is all that matters and ignore the "reviews".
EDIT - Most new passenger car tires come with 10/32 - 12/32 of tread. And the last 2/32 - 3/32 of tread is end of life. They should certainly be replaced by the time we are down to 3/32. And the wear bars are at 2/32.
So you still have a minimum of ~2/32 - 3/32nds of tread life left, according to whether you live in a cold/snow prone area or not. That is calculating with a 4/32 absolute minimum usable tread life. It is not advisable to keep tires with less than 4/32 of tread, unless you only drive in a very dry, no snow climate. In other words, the low desert...lol
Of course, then there are the tire age and other limits that come into play as to when tires should be replaced, no matter how much tread. But that is another story. ;)
1,380
I don't like these tires either, too thin sidewalls.
Hi whatsup. Yes, that is the drawback of buyers wanting larger diameter, fashionable wheels. The larger the wheel diameter, the shorter the sidewall must be in order to fit in the wheelwells.
peterk9
That change in size is not actually recommended. The generally accepted nominal Maximum Diameter Variance is 3% compared to OEM. This change is 3.6%. While slightly over, it can affect systems like ABS, Traction Control and the increased weight will affect the suspension and brake system all which are set up according to the OEM size with slight tolerances. Some have been able to use FORSCan to select preprogrammed tire sizes if the vehicle has them which I'm guessing would then update the ABS and TC.
