Twin Turbo Info ?
Continental Georgia
Atlanta Ga
Hey Y'all!
I was discussing the turbo chargers in the 2.7L 2017 Continental. Are there 2 so there is a lower RPM boost and a higher RPM boost? Are the Turbos the same part number? Are the vanes same or different? Are the specs available somewhere?
4,266
95
48
The twin turbos are 2 separate turbo units. Each operates in its own exhaust port with separate air tubes from the air cleaner. Not likely the same part number but same specs.
There are some links to the 2.7 turbo specs.
