TSB on LS misfire
Forbinproject01
I was just cleaning out my files and came across a TSB on LS misfires. As a previous owner of an LS I had this problem and found this TSB. I also replaced the coils with the latest (at the time) Ford/Lincoln OEM's at the same time.
If this is a redundant post then I will delete it.
Also I had a problem with the engine cutting out and found a TSB for a grounding cable fix if I member it was under the drivers side dash. If I find the TSB and someone needs it I can post it
Did also have a problem with the dreaded sway-bar bushings which I found replacement at Energy Suspension, was a hell of a lot easier to replace than pulling the sway-bar.
Miss my LS
Terry
