Trying to drop the gas tank on a 65
Antony
Hi,
I am a new user and just beginning a 1965 Continental project. It has been sitting for around 15 years. I'm attempting to drop the gas tank to get it vatted but it won't drop. It is wedging between the differential and the trunk. What do I do? Thanks, Antony
LithiumCobalt
2,882
Fort Wayne, IN
Hi Antony,
Should be a matter of releasing the two straps and also removing the fill tube assembly. If you don't have a factory service manual, a highly suggest getting one. They are extremely helpful and will give you all of the details on projects like this. Love the 60's models! I had a '67 convertible for a shortwhile, myself.
4,526
212
If you need some more clearance remove the shocks while axle supported and then lower the axle a little. Be careful not to lower too much and release the springs from their locators.
staylorx
Hi,
Since this comes up #1 or #2 in search in 2018... the manual calls for and I can't get around disconnecting the rear shocks, raising the car, and dropping the rear axle. The rest of it is down the line: empty it, release the fuel tank straps, and completely pull out the fuel filler pipe.
For me it was as good a reason to replace the rear shocks.
G-573712
facing same deal , on a 67 lin.
