Trouble with stalling 96 towny
Godfather52
It started on cold mornings its starts warms up i drive about 1/2 mile stalls. I crank it and crank it and it finally starts. then runs fine. At first it was only on cold mornings. The other day it did it in the after noon. Any ideas? I have a new fuel pump ordered But Not sure if it need it. it has 182000 miles on it.HELP
Jerry
jkeaton
137
Winston Salem, NC
When was your last tune up? Ever cleaned the throttle body? Had it scanned for stored codes? Have you measured fuel pressure to determine if you need a new fuel pump? Blindly throwing parts at a problem will only lead to frustration and unnecessary expense. IAC, TPS could also be failing.
