trans
Anthonyjrojas83
my transmition in my lincoln Ls v6 when put into gear it grabs to indicate its been put into gear but when i give it gas it just revs like if it was in neutral whats wrong with my car
jkeaton
292
Winston Salem, NC
Could be any number of things. Linkage, bad/low/no fluid, bad transmission. Need a lot more information. Year, mileage, maintenance history, etc. Remember that you are the eyes and ears of your helpers. So, you need to be a good witness. Do provide as many details as you can about the problem.
Anthonyjrojas83
When i put it in gear it grabs as if to move foward but when given gas it just reves theres no grinding sound or anything like that but when i was driving it before it went out i had to drop gears all the way down to the lowest gear before it finaly wouldnt go any more in any gear even reverse
jkeaton
292
Winston Salem, NC
Transmission is toast most likely. Have you checked the fluid? Ever done any maintenance? Also, please use punctuation. Your posts are very hard to read.
