These procedures apply to a 2006 model. You can see the exploded view of the front seat showing the lumbar motor assembly as item 9. It consists of a motor and adjustable pad and is held in place with a couple of rivets. If the motor runs but the lumbar pad does not move then the attaching rivets may be broken. Also attached are the procedures to remove the front seat and to replace the motor assembly.
The lumbar motor tightens or relaxes a cable connector to the lumbar adjuster.
