Lincoln Forums Navigation:
Touching up radio faceplate and knobs
44
Thread starter #1
I cleaned and polished a bit of the gunk off the knob for off and on but there is a bit of wear showing around the knob Screen Shot 2018-04-11 at 1.20.09 PM.png the base material is showing through. Is there any touch up for the panel and knob where the silver has come off?
44
Thread starter #4
So Testors model paint in nickel/silver. Pour a bit out in a small cup or vessel allow it to sit for about 5 minutes so some of the solvent bleeds out. use a small oil painters brush with stiff bristles and you can dab it in and come close to the pattern thats there. However, a thorough cleaning revealed several layers of built up finger grease and the original color was still present. The only touch up needed was the very rim of the knob and a few scratches where the gray under plastic showed through.
