silverydragon72
Good to hear any issues so far?I just updated my wife's 2021 Aviator with the new software. The climate control temp is back and the screen response has improved.
Well, Hells Bells, that sounds good!I guess I don't need to use the USB as planned tonight. The update installed itself via WiFi, and yes, the temperature is displayed on the main screen in the circle again. I now have the temperature being displayed in the upper corners of the screen, above the toggle switches and in the on-screen dial when making adjustments.
Have you confirmed that the vehicle 'sees' your network?I was in home wifi range, tried to update it. Wouldn’t do anything. Still says I have build 21098.
Did you have it previously displayed above toggle switches ?I guess I don't need to use the USB as planned tonight. The update installed itself via WiFi, and yes, the temperature is displayed on the main screen in the circle again. I now have the temperature being displayed in the upper corners of the screen, above the toggle switches and in the on-screen dial when making adjustments.
Mine says it’s up to date but won’t let me install this version. I will try again in a few days.Have you confirmed that the vehicle 'sees' your network?
Yes.Did you have it previously displayed above toggle switches ?
Does your account show that the update is available? If so, the vehicle should find it.Mine says it’s up to date but won’t let me install this version. I will try again in a few days.
No it doesn’t . Says I have the most recent.Does your account show that the update is available? If so, the vehicle should find it.
Sometimes it seems that the roleout is done in stages. I've noticed that before.No it doesn’t . Says I have the most recent.
Are you saying it is not functional through your infotainment screen?I just did it too but passenger seat's massage function has become inactive...i'm not sure this is only my case or not... I did not have any issues on last version.... should not have updated it...
Same here when selecting the passenger seat from the screen the massage button is not responsive but other options for the seat are available.Are you saying it is not functional through your infotainment screen?
I haven't checked that out since I don't use the Active Motion features but will have a look later.Same here when selecting the passenger seat from the screen the massage button is not responsive but other options for the seat are available.
Once again Ford Quality is Job 0.
Was anyone sitting in the passenger seat when you tried it? If it is the same as mine, the Massage feature will not activate if the seat is unoccupied.I just did it too but passenger seat's massage function has become inactive...i'm not sure this is only my case or not... I did not have any issues on last version.... should not have updated it...
Checked it out and it works but only if the seat is occupied.I haven't checked that out since I don't use the Active Motion features but will have a look later.
