Sync 3 Climate Control Issue
Anthony202
My 2019 Nautilus has 1,300 miles on it . After being parked in 73 degree weather the dashboard out side temperature gauge read minus 14 degrees. The A/C was blowing air that was neither hot or cold. I took the car to an open road and after a few minutes at 60MPH the climate indicators corrected the readings. That same day I started the car again and the outside temperature gauge read 9 degrees and the fan blowers would not operate. I shut the ignition and restarted the car and everything worked okay. The car was not recently washed so water affecting the temperature sensors is not an issue. Any ideas?
Sagar810
67
Boulder, COLORADO
Washing the car should never have this issue. The outside temp sensor is sometimes a little off but never this off. (-9 on +73). Ask them to take a look at it. Make sure they parkt the car outside on a hot day and then try to switch on the airconditioner (in park) and see if its working or not. Ideally you should be able to enjoy cold air almost immediately (maybe in a minute maximum) after the car has been turned on.... in this case, you are describing something like the temp reading causing the AC not to kick in..
Anthony202
