Speaker Question Revel owners
RoadRage786
27
I have a 2017 base model (10 speaker setup). On my rear tray, I have a long speaker cover going horizontally (covers most of the tray) and 2 smaller covers behind that. Inside the trunk, I can feel 2 cutout holes (feels like 6x9).
What goes in the back of the 13 speaker and what goes in the 19 for the rear.
I wanted to fill the rear with 2 6x9 subs if possible and also put the 3" mids on each door. What are your thoughts guys?
4,714
346
83
Attached are the audio component locations for the Standard, Revel 13 spkr, and Revel 19 spkr systems. I have no idea if your proposed changes will work. The Harman Revel 13 speaker system works great in my car, but I am not into audio systems.
  • 2017 Continental audio Std 10 infotainment component location.pdf
  • 2017 Continental audio Revel 13 infotainment component location.pdf
  • 2017 Continental audio Revel 19 infotainment component location.pdf
Todor
30
Sofia-Bulgaria
The way I see it from Town's attachments, the 10 speaker the differences regarding speaker driver points are very minor in the back line with the 19 driver system having only two mid/hi assemblies more in the rear. Other differences being the lack of mid drivers elsewhere and from what I have read elsewhere, the nice system has class AB amplification and lesser systems having lesser quality power amplifiers. AB stands for higher transistor bias (governing the state of conductivity and reducing so called "crossover error in p-p config. amplifiers") current.
In an automobile the overwhelming part of the subjectively perceived sound is diffuse as opposed to closelistening at home where the main perceived sound is direct. This renders in car listening sessions as ones governed by the total spl vs frequency energy recorded and reproduced as opposed to on axis frequency response subjective experience at home at close distance to the speakers.
Looking at the specific configuration of the lincoln, nothing will significantly improve for the driver by the simple addition of more drivers in the rear line.
What could be improved even in the big Revel which I also have is hi frequency drivers of the front line left and right door. - given that what I hear is due to limited power handling and frequency response and is not a bottleneck somewhere else in the system - DSP or amplifier. - this should be proved by measurements both of the signal feed and the tweeter itself.
What is worth doing in the 10 driver system is replacing the amplifiers with true class AB ones and replacing the tweeters with if possibly bigger and fancier ones with neodimium magnets. Also with some customisation, adding a midranges, again fancy quality drivers is advisable. - all that should be performed by an engineer, professional (who doesn't sell you brands and names, but knows what's he doing) or a knowledgeable friend DIY entusiast - ask your friends if someone participates in diyaudio.com...
RoadRage786
27
Todor, thank you for your insight. According to the diagrams, it seems like the base system only has an amplifier powering the rear sub. If that's true, I would like to add a class ab amp to power the door speakers im replacing (going with Focal Integration ICU 165 on both doors, they come with new tweeters with neomidium magnets. I also plan on replacing the one center 3.5 with a JL audio one I saw on Crutchfield.
RoadRage786
27
Todor, I found a nice 9 channel amp online with DSP built in, which is class a/b for the highs and mids and class d for the woofer and subwoofer channels. Would upgrading the rear sub to the Revel sub but having it powered thru the new amp provide better results than the 10 speaker shelf sub now?
Todor
30
Sofia-Bulgaria
I can't tell you, because I don't know.
Those are sweet ways to gain knowledge and experience. Anyway, if the cost of your incentive doesn't bother you, then it won't be a disaster, because you are going to use quality parts. I have parts from car audio projects still in original boxes that are collectible now. Never used, but don't regret the money.
P.S. Upgrading a sub with a stock sub in the presense of a DSP? LoL I'd go for high-ish Qts low Fs free air sub. - no guarantee on that advice, I'd do it just because I like equipment and stuff, so an addition to my warehouse room is always wellcome - if you understand me.
The Revel is not some kind of high end masterpiece, because those cost 80k USD alone without the 2 ton car attached to it. It's a decent, nice, well balanced way above average on par or better than similar competitor's car stereo. With acknowledgeable, but tolerable, flaws in the tweeters.
RoadRage786
27
I just didn't know what to replace the sub with im it's stock location. It looks like a 6x9 but seems odd based on it's oval shape.
Todor
30
Sofia-Bulgaria
Imho, leave it alone, the Conti has plenty of low bass as is. At least with the Revel Ultima. I even reduce it.
You need midranges and big quality HF drivers.
Amp upgrade is good idea.
