Sound deadening for the undercarriage
NautiOne
Arkansas
Read that this procedure can reduce cabin noise by 5dB. Cabin is already quiet; but what if it can be even be quieter?
Has anyone had their vehicle's undercarriage (and/or wheel wells) coated (either professionally or DIY) with a spray-on sound deadening material (3M, Lizard Skin, Rust-Oleum)?
Will this void the warranty?
Just curious. Thanks!
Black Label
1,590
528
Burr Ridge, IL
Sounds to me like the old Scotch Guard or rust undercoating. I wouldn't do it. Smarter people may chime in, though.
enigma-2
21
There have been a few individuals who have reported the use of Dynamat in the spare tire area, cargo area sidewalls and inside doors made a definite difference. It material deadens by stiffening the sheet metal panels where a drum effect exists.
Undercoating does little in quieting (does little to stiffen large metal panel surfaces) and adds possibility of trapping water between it and the metal; resulting in corrosion.
The first thing to consider is the source of road noise; your tires. Size, rubber type and tread pattern have a direct bearing how much noise is transmitted into the vehicle frame. Michelin and Perelli Scorpions are the quietest but they use solf rubber to achieve this and expect 20,000-25,000 before hard rubber kicks in and get noisy. Bridgestones are a little noisier but last much longer.
