rims and centers
t57f100
thank you guys for the help so far.needing a little more before i put it on the road i just bought this a couple months ago these are the center caps and the one rim but they all look like this is this rash or is this clear coat peeling.i want to approach this very slowly because ford seems to be great for discontinuing their parts.
232
Hi t57. It seems like a little bit of all of the above. There is peeling clear coat, nicks, chips, a little bit of road rash at the wheel edges, etc.
Essentially, the kind of cosmetic things you will see on the wheels of a 20+ year old daily driver.
You could always have them refinished if you want them looking new again.
t57f100
gee thank you so much for the quick reply this could get expensive i guess are these coated aluminum wheels ?can strip the clear off and polish them
232
Hi t57. You are very welcome. Yes, they are clearcoat painted aluminum.
Yes, you could strip the clearcoat, then polish and re-clearcoat them. You would need to clearcoat them (or powdercoat...etc), as bare aluminum will corrode again.
Would not surprise me if they are discontinued, as you mentioned. It will usually be less expensive to refinish them, either yourself or even professionally, than try to replace them.
t57f100
[/QUOTEits going to awhile for sure but i will even if i do a wheel a year so what its not my daily yet and when its done then its done
SGilbert
762
59
South Bend, IN
Long story short, my wheels severely corroded after 2 years. Lincoln replaced them under warranty.
2 years later again, the newer wheels were worse than the first set.
New wheels were over $800ea; tire dealer here said $250-300ea. Found a fella that would strip & powder coat for #250ea, but would have to pay tire dealer to R&R tires.
I went THIS route. Price was lower due to my original choice was out of stock, but they matched these at $161ea. Out the door was a tad over $800.
t57f100
those look great i would like to get to stock with out buying stock now and maybe not clear coated that stuff is ok but its to soft for such a harsh environment
t57f100
i think im going stock steelies and hub caps the rims are easy and the caps are cheap and no worries about clear coat or pitting just change the caps
