Remote Start
stan32225
When I remote start my 2020 Nautilus the rear window defroster comes on automatically? The car is in a garage. I located the settings for remote start and there is no function to disable this feature. Do you think if the temperature is at a certain level this activates the rear defrost? Since the car is always in the garage, I do not need to have this feature turn on every time I remote start the car.
872
Hi stan. Yes, the ambient temperature does affect this function.
It can be turned off in the remote start settings. You essentially need to disable the "Auto" settings. I know how to do it in my MKZ, but can not give you a step by step for a Nautilus. If another member can not jump in with instructions, you can find them in the Owners Manual. Or alternately, take a little time to scroll through the settings.
Cowpix
How cold is your garage? My F150 activates the rear window defrost and heated steering wheel upon remote start when below a certain temperature.
stan32225
Thank you so much for the reply. I will revisit the settings.
stan32225
I live in North Florida. This time of the year it is not that cold. I will wait until a little later in the year when the temperature increases to see if it effects it.
jhartz
219
66
Virginia Beach, VA
Not sure how this works on the Nautilus: but on my 2020 Continental Reserve I can go into settings at set the remote start to start from last settings . . .
stan32225
Update: I discovered the rear window defogger is effected by the temperature when remote starting.
