Rebuild/replace the front suspension?
Hi, I’m planning rebuild/replace the front suspension as the upper and lower ball joint is getting bad.
I do have new front shock absorber in a box and thought I will replace the coilspring as well. Should I also replace the spring insulator (85W1Z-5415-AA), upper mount (8W7Z-18183-A) and bushing (6W1Z-18198-AA)?
I was planning to replace the upper and lower control arm instead of just the ball joint so I get new bushing, and it look easier to replace the whole arm then just the ball joint.
What is your thoughts and experience, pros and cons?
Thanks
