Purchased a 2007 Town Car and obd port not working
Bob Thompson
When I purchased this beautiful car yesterday , I could not get my obd II to come on. I watched a couple of you tube videos and they both suggested it could be a fuse. Sure enough, I swapped out the burned 20 amp cigar fuse and luckily found no problems showing on the monitor. Only other item so far is the passenger window control. I can get the window down but not up from the passenger control. The driver control works fine. Any suggetions?
Bob Thompson
The down works, so it is getting juice. You can try spraying contact cleaner in it, then work it back & forth. Otherwise, a replacement might be in order.
Will try that next week end and let you know what happens. Thanks
