primary timing set
smegun
was wondering what a bad tensioner is ...after inspection I had some trouble unlocking the tensioner to insert the rod i guess its up all the way push guide in all the way then down to grab teeth then insert a small drill bit to lock closed …. after inspection of a tensioner seems ok teeth good springs work ok clever
