Power Steering Fluid
04 LTC
Chicago
What are you guys using? Manual calls for Mercon ATF but that was discontinued years ago. I see things online warning against mixing with Mercon V in the trans. Not sure that info applies to power steering pump. I don't intend to fully bleed, just swap fluid at the reservoir a couple times so the new fluid will mix with the old.
Thanks.
